kevman65
Finally got around to getting harness side, rear driver side, speed sensor connector spliced in.
Took longer to get everything needed to do the fix, than it took to do the fix.
Once done, got in and started the JT, didn't recognize the fob. Used the fob to push the start button and started up. Drove around the `hood, no warning lights, 4x4 works again, didn't test cruise control. Get home and park, shut the JT off, opened and closed door and waited for everything to turn off so I could go into Tazer and check/clear codes. Won't go into Aux, still doesn't recognize the fob.
Get out, lock doors with fob (works) set alarm (works), unlock with fob (works), get in and try to start, doesn't recognize fob.
WTF?
Oh yeah, 2020 Rubi JT
WTF?
