catahoula
Ok. I had installed some EVO corners. Now at least everyone has had issues with a nutsert coming loose as you are screwing in your bolt. Everybody that had dealt with this knows how much of a pain in the ass it is to fix. I figured out a solution and wanted to share with everyone. Once you get bolt out it is smooth sailing. Measure where the bolt starts to twist the nutsert. At that measure is where you will cut bolt shorter. It will then fit into nutsert and still tighten but not stick out as in first picture. This is called a "fake it fix". I am uploading pics per step with tools your will need. Hope this helps someone. My pics are shitty so I apologize.
This picture I had another issue like the first picture the bolt on lower panel was sticking out. I cut and shortened this one and now looks so much better.
