jku_robert
Just wondering what's the difference between in performance between long arm, mid arm, and short lift kits. Thanks
I'm completely stock right now I was about to put on a Rubicon express 2.5 coil lift but I rather wait to go with a 3" or 4" lift. I've been looking at skyjacker, teraflex, rock krawler, Rancho, and the evo enforcer.
I've search what everyone has said about the lifts here and mostly everyone that runs the evo enforcer is happy with it. I guess since I'm new to this I though the more components the lift kit has the better.
Yeah get the enforcer you'll be more than happy. FYI if you get 3' you might be able to get away with not having driveshaft issues but their is a good chance you driveshaft will hits the exhaust crossover and possible burn the boot. It is recommended that you do get a new double cardan shaft.
You can also add the evo long arm upgrade kit to the enforcer later, pretty much making it the double D. That leaves you pretty setup for bolt on or double throw down coilovers later on if you if you see them in your upgrade path![]()
Sent from my LG-D800 using WAYALIFE mobile app
