Rancho
Rancho's Front Dana 44 and Dana 30 differential Glide Plate for the Jeep Wrangler JL mounts to the front axle casting, and allows for a much smoother glide over obstacles forward and backwards. The Glide Plate protects your differential casting from direct contact in severe offroad conditions. Works with OE and most aftermarket differential covers. Manufactured from 1/4" high-strength, low-alloy steel and covered in a durable red powder-coated finish.
Rancho® JL Rear Shock and Control Arm Skids are designed to protect your JL control arms and shock absorbers from rocks and other obstacles. Made from 1/4-in. high-strength, low-alloy steel, these skids will glide over obstacles and keep you moving down the trail. The Rancho Rear Shock and Control Arm Skids bolt-on using the shock and supplied control arm bolts, and are powder coated in a durable Rancho Red. Driver and passenger side skids included.
