New Dana 30 axle shafts
Manvan
So this past weekend I managed to blow up my drivers side axle shaft. After looking at my options, I came across a replacement axle made by Dana. The specs say rolled splines, alloy construction, and larger 1350 life u-joints. They make them for the D30 and the D44. Also, the driver was $219 and passenger $279. Anyone heard of or using them?
I would look into a set of chromoly axle shafts with full circle clips personally. All of them are the same so just look for a cheapest set you can find.
What ball joints are you running? Make sure the larger u joint will clear the ball joint. Other then that there is no issue with them.
