M mastrcruse New member Sep 7, 2017 #1 After 3.5 years and 40k miles I believe I have a brake line leaking. Any recommendations on new brake lines? I'm on a 3.5" RK lift if that helps.
WJCO Meme King Sep 7, 2017 #2 What are your symptoms? Rancho makes some and Clayton makes some. I believe either will suffice for your lift height.
madstiles New member Sep 8, 2017 #3 A local hydraulic hose shop can make them and usually cheaper also supports local businesses Sent from my SAMSUNG-SM-G935A using WAYALIFE mobile app
jeeeep Hooked Sep 8, 2017 #4 I've used Clayton and switched to Russell Performance when I put the 37's on.
jonathanbottoms New member Sep 8, 2017 #5 I installed Crown Performance lines front & rear with my 4" Rancho lift. No complaints here Sent from my Pixel XL using WAYALIFE mobile app
I IgotaWoody39 New member Sep 18, 2017 #6 Is it a Hard line break ?? If so, mopar lines found here......https://www.moparpartsoverstock.com/showAssembly.aspx?ukey_assembly=900849 Just make sure you adjust for your year on the site..... Last edited: Sep 18, 2017
TheGrendel Active Member Sep 18, 2017 #7 i have evo in the front and crown in the rear. just happened that way as i found good deals while hoarding parts.
