New Axles for the Jeep
monstrousmac
Well, I got my new axles for my Jeep. A Dynatrac Prorock 44 front axle with 4.88 gears, ARB Air Lockers, Reid Knuckles with Dynatrac prosteer ball joints and RCV axle shafts. The Rear Axle is a Prorock 60, Arb Air Locker, 4.88 gears and Dynatrac Axle shafts. Thanks to Mr.Elms.
So does anyone know of a way to get a good measurement for drive shafts, without having to pull my existing axles off and bolting the new ones on and measuring? My Jeep is my daily driver.
I tried doing this back when I swapped those same axles in. The front is pretty easy, u can just get one for a 44. The rear in mine was a total fail. You are going to either need to install and measure. Or find someone that has same setup - engine, trans, suspension, lift - and have them measure theirs. I was assured by JE Reel "they knew what I needed because they do so many" and it was inches too long when it showed up. They did make it right but valuable lesson learned.
Sent from my SM-G960U using WAYALIFE mobile app
