OverlanderJK
Resident Smartass
Your camber is pretty high as well. Spec is like 4.2 or somewhere around there.
You can’t adjust camber.
The camber isn't really all that bad. Caster has a .4 deg split which could contribute to your pull. I agree the adjustable parts can make the alignment guy look good on the print out, but tend to "adjust" themselves off road and usually cause more problems. I would just run it and rotate often. Every 3-5000 miles including the spare tire WAYALIFE mobile app
Compression shims do exist. I hate them but they do exist.
Why do you hate them? I understand it’s preferable to have a straight axle housing, but for someone with $25 and not $1000, what’s wrong with the shims?
Well technically that would be changing it and not adjusting it.
