Review this writeup as well
http://wayalife.com/showthread.php?4091-TECH-TIP-Jeep-JK-Wrangler-Steer-Stop-Adjustment
Your tire is rubbing your stock(rubber) brake line? No, that is not good. I wouldn't run that way for two weeks.
do you have extended after market lines or stock lines?
are both brake lines rubbing or just driver side? usually the driver side will rub because of the brake lines curve, if this it he case you can zip tie it loosely out of the way.
but some pics showing what you are seeing would be helpful
