So the jeep build is brand new, just took it
Home last week, it's already gone back to the shop and it's still not fixed. There is a rubbing/grinding noise when my wheel is fully turned to the right, and based on these pictures it's my tie Rod coming into contact with something. Clearly either my trackbar bracket isn't installed properly, or my tie Rod isn't installed properly because if feel like the 2 shouldn't be this close and certainly shouldn't be coming in contact. They mentioned something about the synergy instructions not showing you had to remove the factory trackbar bracket before installing the synergy, and that they were going to trim some of the factory bracket off. If something isn't installed properly and is causing the rubbing, I don't want bandaids I want them to take it apart and fix it. B please let me know if something looks off to you.
