JordanHaskin
A little( ok pretty long) back story. Back in October I went on a wheeling trip and at some point hit my RF lower control arm mount hard enough to bend it and knock( I know, the shitty) cam bolt out of adjustment and screwed up my castor. Didn’t drive it much after that until winter but noticed a bit of feathering on my tires from the toe being out. So now before the roads start to warm up I decided to get an alignment done at a buddy’s shop who isn’t charging me or I would do it at home. My castor was around the 1.3 degree mark on both sides and toe was out. He couldn’t get me a printout as his computer was doing an update. So they adjusted castor to 4.2 degrees and adjusted the toe to spec and on my way home I hit a set of rail road tracks and I suddenly have death wobble. Went back and they turned castor down a bit seeing it was happy there before. Still has death wobble. I went home and had my wife rock the wheel while I checked things out and noticed my TB flexing a bit but bolts not moving so I put the adjustable one from my lift back in, torqued to 125 FT/LBSand centred my axle and test drive- still have DW. No play in DL or TR ends. Jacked up and checked BJ’s- no play. Checked wheel bearings- no play. Front lower arms have a bit of play in the bushings. In October I did a DL flip with raised TB bracket. I rotated my tires back to where they were last week and test drove it- still DW. Any other thoughts? Any help would be great because I’m not ready to pull my car out of storage yet and need to keep driving my Jeep.
