To the best of my knowledge, EVO does not make a 3-link.I’m not sure what the kit is called. It’s an Evo kit. 3 link, long arm. It’s not the cantilever rear.
Can you post up an actual pic of your rear coilovers? Curious to where your timing rings are set.10.200 over 12.250
150psi at droop
I will later. Gone right now (the wife's daily).Can you post up an actual pic of your rear coilovers? Curious to where your timing rings are set.
The whole point of coilovers is that there is no specific setting. They are designed to be fine tuned with different valving, preload, timing and spring rates to give you what you're needing for YOUR SPECIFIC rig.I will later. Gone right now (the wife's daily).
The slider is sitting on the timing rings at ride height. Just barely. You can lift the bumper with your hands and get a little separation. I'm not positive, but I believe the previous owner added a fifth tire/wheel, I don't think the original setup had a spare on the gate.
I'm really just looking for a setting (if anybody has one). What I've got is mostly fine on the street, but it's way too soft on the trails. I'm about to start changing things, but thought someone here might have a setting I could go off of initially and not chase my tail too much.
That said and if you're secondary is really already at the point of engagement, how much preload do you have set on them? If not a lot, try adding more. If you do already have a lot, heavier spring rates is probably something you'll want to be running.
Not much preload at all on the secondary. Is it typical to have preload on the secondary at ride height? I could put more on it. I'd rather not raise the ride height any, but I'm not opposed to it.
I know my way around, mechanically. What I've never had personal experience with are dual rate coilovers. I know they can be setup a thousand different ways, depending on the rig and driver preference. Just curious if anyone had a setup already that works well, so I could at least start there.
Awesome! Adjustability is a big part of what make coilovers so nice.Update...
The thread above was a huge help. Before I tried anything else, I wanted to try what @wayoflife had suggested above, and add more preload first.
So as stated before, I had already timed the slide stop down and the bottom spring (on the rear) was engaged at ride height, but just barely. So I added 5 turns of preload (on the top adjuster) on all 4 corners. I ran the timing rings down an inch or more on the rear so that the bottom spring was under some preload at ride height. Then I adjusted the rear about 1/2" higher than the front, and leveled it side to side. Overall, I raised the ride height on the front maybe 3/8", and about 1/4" in the rear.
I immediately noticed a difference on the street. Just a bit more planted. Takes dips, driveways, etc with a lot more confidence. Less "squashy" feeling. But the street wasn't my complaint...
Finally was able to get out to Choccolocco Mountain and do some trail riding. Huge difference. I did bottom the rear out once, but I let it come off a big rock a little too hot, so I'll blame that on the driver.
I still think the bottom springs on the rear could be a touch heavier to make it perfect, but just adding a good amount of preload on that bottom spring at ride height made a massive difference. I'll probably just leave it alone at this point.
Just wanted to update this thread. Moral of this story, small adjustments on coilovers can make a big difference in ride characteristics. Again, appreciate all the input!
Awesome, congrats!Update...
