rich67
So recently I developed a really bad metallic grinding noise that at first sounded like it was coming from the gearbox (I have a 6sp), but after some investigation led me to underneath the Jeep in the area of the crankshaft pulley (?). The noise comes from that region and into the area of the crankshaft. I uploaded a video of it to youtube:
I had the clutch replaced and the noise went away a little. But I still hear the noise (not as bad as in the video), and it is a constant, not- RPM- dependent noise. When you turn the motor off, there is a slight grinding noise as if something is rubbing or a bearing is failing as the motor winds off, and there is also the same noise on startup.
I have had the engine ticking for about 40k miles, and am worried the crankshaft or something else is failing. About 8 months ago the engine was throwing "cylinder misfire" codes, which I cleared out and they didn't repeat after a couple times.
So bear in mind that after the clutch job the noise is significantly less than on the Youtube video I posted, but it is still there, noticeable more at idle at a light and upon engine startup and shut down. Any help would be appreciated so I can go into my mechanic and not look like a complete moron.
