Need help with Dana 60 front calipers
SLO
Trying to get to the pads in Fusion 4x4 front calipers (Dana 60’s). I removed the top pin to rotate them down. The rears were easy and I only needed to remove the top bolt and they pivoted down to access the pads. On the front, it will only pivot about 1/2” and and it hits hard against something. It’s like there is a pin or clip that is stopping the rotor from rotating down. I have done searches and most show either a torx screw that needs to be removed or a clip that slides out. I don’t have either of those. Anyone know how to get to the pads without removing both pins?
