toxicwaste29
I am currently having to issues with my jeep:
1. When going over bumps I hear a clunk sound coming from the rear. I have looked everything over and everything is tight. It seems like all that is left is to start unbolt every control arm, sway bar, and the track bar and inspecting the bushings. Is there any other way of inspecting for the issue or is this it? Also is there something I should look at specifically?
2. When I first start my jeep and it is cold I hear a loud ticking sound coming from the engine bay. It is drivers side. Im not sure if it is my head or exhaust manifold. When the jeep warms up the ticking decreases in volume however it can still be heard under low rpm when the engine has a load. I haven't gotten any check engine codes for the head since its an early 12 so Im not sure if that could be the issue. I have poured sea foam into my brake booster vacuum line and there doesn't seem to be any smoke coming from near the exhaust manifold. Any ideas on this one?
Thanks for all the help in advance.
