need help with a stuck oul filter.
dunstan74
I would really appreciate sone input on hiw to fix my massive stuff up/lack of using my brain. I was changing my jeeps oil filter and the tool I used crushed if really badly without budging it at all. A internet search told me lots of people stick a screw driver through and wrench it off that way, well that worked great until the screw driver sliced the whole thing in half making a huge mess of it!! So looking at the picture so amy have a clue how I can get this sucker off??
Stick something in the holes and try to twisted, if not I seen this socked with like sticks coming out of the top you can use that to brake it loose, or the a pipe wrench and brake it losse from the middle
Is there any chance of damaging the area thr filter attaches to the engine poking thinh through the holes?
How about using a long punch and using it to tap the filter in one of the holes at the base to un-screw it?
A few taps might do it but don't hit it too hard as you could tear the base as well. Good Luck!
Take a screwdriver and a light hammer and try to tap it in the direction to loosen it. Just be careful because the housing is aluminum. Spray some pb-blaster around the outside of the filter and let it sit for a few. Just an idea. That really stinks, don't go back there for an oil change. The filter should basically only be hand tightened when installed to prevent this issue.
Thanks for your help, this is the first change since buying the jeep from the previous owner so they must have overtightened it alot then. This thing just wouldn't budget
Good luck with it! A beer at this point might help, maybe even a 6-pack. :eek:
For future reference, use a strap wrench with a 1/2" drive extension and ratchet. It'll grip really hard and will crush it some but will get it loose.
maybe it's the way the photo appears but the way it's crushed it looks like you were tightening and not loosening. when using a screwdriver tap gently and move around the inner holes so you distribute the force.
Good luck!
Same as all the above but remember you are going anti clockwise to undo and if you damage the base that it's screwed to then that's a whole new can of worms. If you could make something that just fits into two of those holes (on opposite sides to each other) and gently turn it that would be the safest way. If your not confidant perhaps tow it down to your local garage and save yourself the stress.
Even oil filters that are tightened correctly have a habit of becoming stuck like that over time so it's hard to blame the guy who serviced it really. Good luck.
Yeah its on its way to the shop im not messing around more than I have already thanks for everyones input and suggestions. learnt a valuable lesson to take more care with simple tasks, live and learn I suppose!
That is the exact reason you don't use a wrench to tighten oil filters... hand tight only!
THIS!!! I have never used a tool to perform a filter change in my life. It only takes a little bit of leverage from one of those tools to accidentally tighten it too much and become a bitch to remove. Good luck getting it off!
How do you remove the filter cap on the pentastar? Just kidding, that's another reason I like the new engines, oil changes are so much easier.
