Need help installing my aries brush guard.
Jeepney425
Hi guys, I bought this aries brush guard from a fellow jeeper. My problem is the top mounting brackets is short by 1 1/2inch on the driver side. The other problem is that, the air pump is the way of where I can bolt it into. I'm not really a savvy mechanic. If I take off the air pump and drill a hole so I can mount it, would there be any problem if I took off the pump temporarily? I need your opinion on this. I've been itching on mounting this guard and can't wait on how it looks. Please help. Thank you
Here is the pic of the brush guard.
http://www.autotrucktoys.com/jeep/i...r-Aries-Black-Powdercoated-Grille-Guard-C.jpg
you will have to relocate the air pump. a couple of manufactures have relocation kits but there is a thread, just cannot remember the title, which has a DIY vac pump relocation.
is the brush guard made for your year model JK?
Edit: here is a link to DIY vacuum pump relocation. http://wayalife.com/showthread.php?6271-DIY-4-23-Vacuum-Relocation&highlight=vacuum+pump+relocation
R/
Will
Thanks dude, will there be any problem once I unbolt it? All info, I can find out is that it fits up to 12, not mine which is 13 JKUS. I will just have to do this relocation, so I could mount that top bracket. Thanks for the help. I will post pic, once I come back from a trip. Thanks again.
If it fits a 12 it will fit a 13, once you relocate the pump it will most likely line right up.
