monstrousmac
Ok, I have a leak in the front of my JK by the radiator. It is not the radiator because I just changed the radiator with a new oem mopar one. My radiator was leaking initially, So, this leak seems to be an oil substance, my oil, transmission and power steering fluid levels are right where they need to be. The fluid is dripping from the shroud that covers the bottom of the radiator and condenser. I have checked the lines and they seem not to be leaking. I feel like I am chasing gremlins. But the oil is spraying back and you can see the residue on the frame, control arms etc.. I figure with the looks of it, I would see a noticeable drop in fluid levels. I might end up having to pay the 145 dollars to have it checked by the dealership here in Tucson.
Does the Condenser run oil through it. Because I just looked again and the passenger bottom side of the condenser looks wet. Oh, also to note, the AC does work.
Any advice would be greatly appreciated.
