Colorado4x4
My 2016 Jeep JKU with 65,000 miles threw a code yesterday morning for P0300 - multiple cylinder misfire. This was while pulling out of the neighborhood on my commute to downtown Denver. I was idling down a small hill when the CEL came on. I cleared the code and made the 35 minute drive and it the check engine light did not come back on. The CEL did not appear on the commute back home at the end of the day yesterday (45 minute drive).
There were no symptoms that I could tell. No popcorn sound from the exhaust, no loss of power or engine shaking at all. I checked the resting battery voltage this morning and it was 12.7 V. I fired her up and checked idle charging voltage and it was 14.1 V. It appears the battery and alternator are ok. I then went on a 5 mile drive and did not get a CEL.
This is the first time that I have had this code P0300. It has been raining here a lot and we hit Spring Creek on Sunday and it rained the whole 2nd half of the trail as well as raining hard on the way home. Maybe the rain had something to do with ECM power/wiring?
I read online and usually if it was a serious misfire the computer will tell you which cylinder is misfiring. Also, if it is serious the CEL flashes, which it did not.
Here is what I am thinking
- wait to see if the code comes back and not jump to conclusions. Could it be bad fuel?
- check spark plug wires and coils. I am still running original spark plugs. How many miles have you guys gotten out of the OEM plugs and coils?
- check fuel pressure
- check for vacuum leaks
- check EGR - I have no idea how to do this so will look for a write up here. I think I saw one at one point
Thanks!
Thanks!
