silverbackjk
I am trying to figure out the best way to mount my lights to my evo quarter pounder bumper. I you are using this bumper lets hear what you did even beter if you have some pictures.:thumb:
They make a light bracket.
If you have a roller fair lead drill a couple holes on the top side and you got a light bracketthat's what I did on my or fab bumper and will be doing on my 1/4 pounderView attachment 17454
If you don't push the limits how do you find them??
I don't have an answer. Actually another question... I have read that if you run the EVO stinger with 1/4 bumper that the slots designed for the hi-lift jack will be inaccessible.
My ideas was to cut out those slots in order to mount some rigid dually flush mounts.
Any thoughts...?
As shown above, I've drilled the fairlead on Moby and attached lights there. However, the winch hole is off center so what I did is stack some washers on the driver side and attach 1 light there. I then installed a piece of bar stock to the passenger side to offset the light there and mounted the other light to the end of it. I'll try to find a pic to show you what I did.
I would love to see this setup if you happen to find the pics.:thumb:
I would have just gone outside and snapped a pic for you but, Moby is still at the dealership :sigh:
Wow still?!
Just tried to put the part number in Northridge with no luck. I am pretty sure if you call ORE they will provide an answer.
