Ordered it last Tuesday and came today. Can’t wait to get it installed. Pads are twice the size of stock
Current Mopar BBK for JK includes 13-inch rotors, dual piston calipers, brake lines, heavy-duty pads for the front axle and a matching brake booster and master cylinder. Most kits run under $800 but are on back order 2-3 weeks most places including dealers. My dealer wants $600 to install if you’re curious about that as well.Is this for JK? Does it include rotors? And what is the cost on the kit?
Is this the JK8 kit? Do you also have to change the MC?
Definitely the most complete kit on the market. I think people get too caught up in thinking bigger rotors and pads are all they need when in reality the dual piston/bigger piston is a huge factor IMO. Bigger rotators and pads are great but you need a bigger caliper to take advantage.
Just hoping everything will fit with the bead lock wheels
I think people get too caught up in thinking bigger rotors and pads are all they need when in reality the dual piston/bigger piston is a huge factor IMO. Bigger rotors and pads are great but you need a bigger caliper to take advantage.
Umm, not really. I'm not saying that bigger pistons and a new MC wouldn't make a difference, but for the guys out there running the Dynatrac kit that can simply bolt it on and use stock size pads to generate braking like this video shows with big ass 40" Mud Grapplers on 20" wheels, how much more do you need? :idontknow:
While the Dynatrac kit is quality I'm sure, I feel the performance increase for the price is far too much. IMO the pricing comes from ease of install which is understandable but Dynatrac relies heavily on their proprietary brake pads. While bigger rotors and better brake pads are great things my mindset on brake systems comes from my motorcycle racing background. Granted it's a race bike not a Jeep but brakes are insanely important on them so you learn how even the smallest changes such as high temp brake fluid can reduce brake fade, etc. We never upgrade to bigger rotors on bikes, our primary focus is heat resistant materials on pads/rotors such as ceramic and increasing pressure to the rotor. Next would be calipers, master cylinder, stainless steel brake lines, and high temp fluids. Reducing heat/fade while creating more pressure is key to any brake system.
Pretend your index finger and thumb (single piston caliper) are squeezing together an egg now use your index, middle finger, and thumb (dual piston) caliper...which one will create more force to break the egg? It doesn't matter how big the rotor is if you can't squeeze it hard enough. On that same principle you can increase the egg/rotor size to create more leverage with the singe piston but ultimately you would want to do both. Consider all brake pads equal; Dynatrac uses bigger rotors, Teraflex uses bigger rotors/dual pistons, Mopar uses bigger rotors/dual pistons/MC/booster/brake lines. All these kits work but the Mopar kit is by far the most the most complete and its cheaper than the other kits. I would also like to see how Dynatracs system performs if you swap out the proprietary pads.
Don't take this as a bashing on any company but there are differences between them all.
