I recently installed the Mopar big brake kit on my 2009 JKU-R, and have had nothing but problems ever since... I bench-bled the master cylinder until there were no more air bubbles coming through the lines (pretty standard stuff), and replaced the booster, master, front rotors, and calipers without much issue. The problems came when it was time to bleed the brakes and actually put them into service. When I bleed the rear brakes, the pedal stops solid about 1/2 way down - it will NOT go all the way to the floor? When bleeding the fronts, however, the pedal goes all the way to the floor as you would expect. The real problem is, the brake pedal feel is now terrible and it takes about 2/3 of the pedal travel before anything happens at all? And worse yet, often times while sitting there with light pedal pressure applied, say at a stop light or something, the pedal will actually drop away from my foot and I have no brakes at all until I pump the pedal???? Just looking for ideas on things to check, tests to run, etc? Oh, and I've got a buddy that has the Chrysler scan tool to perform the ABS system bleeding, and we did that as well with NO change :icon_crazy: Thanks in advance for any help.
