Montana Winter Jeep Prep
Jsouder53
Moving from Florida to Montana this will be the first real winter that our Jeep has ever seen. Our Jeep has yet to see snow. All I know is that I need different washer fluid so far...
Just wondering what else people do before winter.
*It is not a garage kept Jeep
That's about it. You could look into a battery heater and oil pan heater if you're going to be in -10 or colder.
Get a quality battery.
When mine wasn't in the garage here and it got single digits or colder, I would still drive it around a couple miles even if I really didn't have any plans to go anywhere. Just to move fluids around and stuff.
When it's that cold, also be careful working on anything plastic as it can easily break.
Always let it idle for a few minutes after starting just to make sure oil is circulating around.
Get an ice scraper. A real one. Not one of those ones that will fit in your pocket. If your Jeep is going to be kept outside you will need one. These work really well and are available almost anywhere that it snows. Also a good idea that if there is snow on the forecast over night to fold out your wipers so they aren't touching the windshield. The rubber on the wiper gets brittle and if you start scraping ice and hit the wiper blade that is frozen to the windshield it will sometimes tear. Just personal experience and preference on both. Congrats on the move!! Montana is beautiful!
Sent from my Moto Z (2) using WAYALIFE mobile app
Oh.... And the brush is for clearing all the snow from your hood and painted surfaces so it doesn't blinds you when you start driving....
^ Agreed. Especially if you've been driving it the day before. The warm interior temperature of the Jeep causes the fresh snow on the outside to melt and make water around the wipers. Overnight this area becomes a block of ice.
Remote starter.
Emergency supplies.
Recovery supplies.
Rust prevention, wax, paint, undercoating.
Thick weather resistant floor mats.
Check your coolant, up here we call it antifreeze.
Depending on what you’re used to running you may switch your oil thickness choice.
Switch from light beers to dark.
I live in Helena Montana, nothing special other than windshield wiper fluid. Blockheaters are cheap to install if you want one. I even run a soft top all winter long. Last winter we hit -32 degrees and no issues.
Awesome [emoji106] I’ll definitely put quality battery on my list.
Thank you! That’s exactly why we moved here! We ended up getting one of those ice scrapers [emoji106] thank you for the tip on the wiper blades as well
Remote starter.
Emergency supplies.
Recovery supplies.
Perfect list! [emoji736] to most of those. I’ll have to look into the antifreeze and I run 5w-20. Would it be smart to switch to 5w-10 or something similar?
We will have to meet up at some point! -32 that’s crazy! Glad to hear that the soft holds up to the cold like that
You have the right advice so far.
The 5w-20 oil is fine.
One more thing, don't use your emergency brake. It can freeze if set after driving then left in sub freezing temps.
I know, I'm is SoCal now, but grew up in Northwest Colorado. Coldest morning I went out in was -56. I recall weeks on end of never getting above zero, and hitting -40 every night.
That said, you are in beautiful country, and I would have no problem going there to get out of the rat race.
Thank you for the tip on the emergency brake and the oil!
There is plenty of space up here for you when you are ready to leave the rat race!
Battery can be an issue for sure we hit -11 over here in WA last year, and I had 2 starts where the battery just barely turned the motor over. I'd definitely carry a bottle of hand sanitizer w/ you to get the door locks and windows thawed out. Has saved my ass a couple times.
I use a Optima yellow top.
Awesome, thanks!
Hand sanitizer to thaw out door locks? Lol
https://wayalife.com/showthread.php/52442-The-Build-and-Adventures-of-Bearbait
A collapsible recovery shovel is small enough to keep in back without taking up to much space and can really come in handy
