silversurfer575
Hi all.
Ive been reading a lot, learning a lot. Have made some investments in my build that I really should have not done (Reids, RCVs) because the parts wont carry over to a new PR44 UNL. Hoping to recoup some cost if I can sell my current built axle.
Heres where I want to go:
1. PR44 Unlimited Front Axle
2. EVO adj LA kit
3. EVO Bolt on Coilovers front and rear
4. regear to 4:56 or 4:88
5. King bumpstops
6: armor up the rear corners
7. Upgrade rear axle housing and shafts. Not sure what to do there yet.
8. ARB front and rear
I cannot afford to do all of this at once, so Im trying to figure out how to do this in pieces. I kinda screwed up by getting the RCVs and Reids for my current axle. I originally thought I would be able to use the RCVs and the REIDs with the PR 44. Misinformed, I can use the Reids, but may just leave them on my current axle and sell with that.
I do most all of the work on my Jeep except welding, alignment, and gears.
That being the case,
1. Can I install the PR44 in the front, with the ARB and the 4:56 or 4:88 gears installed, and run the 4:10 in the rear, for about 20 miles, until I can get it to a shop for the gearing in the rear? I could just not connect the driveshaft to the front......will that work?
2. I blew it on my current front axle. I thought I would be able to use the RCVs on the PR44, but realize that I cannot. For the rears, are there axle shaft, gearing, locker combos that I can do to the rear axle, that I can transfer to a heavier duty housing later? In other words, can I upgrade to ARBs, 4:56 or 4:88s, and heavy duty axle shafts (what brand do you suggest?) now?
3. Bolt on coilovers front and rear: Is it better to do the fronts first, then the rears, or ?
4. I hear I can run adj short arms with the coilovers. I have TF arms, which I will want to change out, and most likely go with the EVO LA, so I have more ground clearance. What are your thoughts about when I should do those? Before the PR44? Before the coilovers?
Note: I have a 4inch total lift between coils and spacers.
I run 35s and do not intend to go any higher.
My rig is a 2012 2 door JK rubi, automatic.
Thanks for your thoughts.
2. EVO adj LA kit
5. King bumpstops
