Last night I changed the oil in my 2014 JK with 133,000 miles on it. I’ve been having a ticking for a month now that was faint at first but is progressively getting louder.
Based on what i have read and where it is coming from I believe it is a driver side rocker that has a bad needle bearing.
This afternoon I looked at the filter to check for metal and sure enough, some small metal flakes on the filter pleats. I assume they are from the cam which is expected due to my dumb#$$ procrastinating.
My questions:
Assuming the metal is from the cam lobe and has only been present for a month, would the presence of metal in the engine cause other engine failures?
Should I have the service tech drop the oil pan to clean out any other metal shavings and/or test the oil pump (I’ve never gotten a low pressure code)?
I use full synthetic Castrol and never go over 5000 miles between changes.
I made an appointment at the dealer last week and I am dropping it off tomorrow but I want to be prepared for their questions.
My questions:
