Cam
Installed the Dynatrac Pro Grip brake kit and went to power flush my brake fluid and it was dark black. Brakes stop much better but still slowly goes to floor when at stop. Looks like my Master Cylinder is dead? I was going to replace with OEM but also saw the Mopar Mopar/Jeep JK "J8" Master Cylinder/Booster Kit - Mopar (P5160050). About $200 vs $100. Would this help with my Dynadrac break kit and be an upgrade or not nessessary? Emailed Dynatrac but no response after about a week. Tried to call but was on hold for a while and thought I would tap all the knowledge on this board. Don't see upgrading to Mopar big brake kit but if I ever did the J8 Master Cylinder and Booster would already be in??? What you guys think? Would it run ok/better with Dynatrac Progrip? Also with either Master Cylinder would a bench bleed on the Master Cylinder be OK or with the ABS should I have the dealer do it?
Thanks in advance.
Cam
Thanks in advance.
Cam
