ghostryder
Anyone heard of these are they any good?? Whats your opinion??
I have there engine/tranny skid on my JKU and it's saved both numerous times. I've had to take it off a few times to flatten it back out as I wheel hard and smashed plate into exhaust crossover. Didn't hurt exhaust at all, would just make an annoying noise from the exhaust vibrating the plate. Overall happy with it.
If you've had to flatten it back out a few times then it really doesn't sound like it is doing it's job and the more you have to flatten it the weaker it will get.
It's done it's job well. And yes if course it's getting weaker. If you'd seen where my rig's been I think you'd have a different comment. I know there are better skids out there but for the $$ it's worth it.
Forget the weight of the aftermarket stick with stock, just get a go oil skid.
Depending on his setup, he may not be able to run the factory skid.
I put a 3.5" lift on mine the drive shaft would make contact. So it had to be replaced with something different.
i have a 3.5 lift as well
With that much lift I bet your drive shaft hits the factory skid at full flex. Heck I bet It doesn't full flex by the time it makes contact with it.
And I do not suggest no plate. You just never know when your going to need protection. Spending some money on skid protection could mean the difference between getting off the trail or not.
Just my opinion.
Just my opinion.
awesome thanks for the info
you would honestly suggest no skid plates?
