ttfhell
Made the mistake of using my front locker today. Always engages ok but have to use the ol' screwdriver trick to disengage. Did the trick, looked right felt wrong. Repeated. Still felt locked as steering is hard when slow, tires chirping, and under/oversteers at speed. Drove home from Azusa Canyon Fun! Pulled diff thinking maybe the bottom of the ring still engaged. Took these pics. Looks about as un-engaged as it gets. Jacked front end off ground both tires spin same direction when hand turned. Now wont engage either.
Used it when I got hung up on front diff/driveshaft. Ended up getting strapped back. Heard a slight pop when getting strapped. Don't know.
Drag link was already bent a little. Filed down the driveshaft a bit on the rock and nocked the cap loose. None of which I think have any direct effect on my problem. Any ideas? What did I break? Is there something obvious my newbieness is missing? Axle shaft?
Thanks
Russ
Thanks
Russ
