Line-X Questions
jorgelrod
I plan to Line-X the bed soon, I also want to add the 110V connector on the bed. I saw the videos and besides having to remove half of the dash to replace the bezel where the switch goes it looks simple enough. Should I wait until I do this to Line-X the Bed, or does it not matter? Second question is my truck did not come with the rails, what would I need to remove the line-x from the bolt holes for the rails as I figue they will most likely get product inside them.
Get wood golf tees and insert them in threaded holes. Tell Line-X guy what they're for and he'll remove them when done.
Can't help you on the outlet except to say it would be easier to have the cover installed before spraying.
Really doesn’t matter, have them cover the mounting holes so they don’t spray into them. Line x isn’t paint, it’ll plug the hole completely.
Line-x will also put a lame branding plate in your bed unless you tell them not to! They also blew over some of my drains….
