Lift kit advice
Adamw1212
Looking to get a lift for my jk. I know I want to start with a 2.5" lift but could use advice on if I should go with a budget boost or the suspension lift. Looking at a teraflex 2.5 basic suspension lift or the teraflex budget boost kit. I would like to get into some off-roading but since I'm new to this and in ohio where it's somewhat flat I know it won't be anything to extreme.
From reading a lot of posts on this subject and doing my own research + asking other members I'm going to be using an enforcer kit by Evo. From a recent post on here a member used the Evo leveling kit and said it was much better then stock, if your on a budget. The 3" enforcer kit will take care of most of your needs with minimal parts needed. If you have a budget let everyone know and the members here will set you on a good path.
Hard to say what you need. You will get a thousand opinions. But what you need to do is educate yourself of the components of a lift for a jeep and then figure out what your ultimate goal for the jeep will be.
I prefer to go with a lift that has the capability of being upgraded or added to without wasting money and going backwards. That usually means buying a quality lift and it's a bit more money up front. Cheaper is exactly that so be careful.
This ^^^^ plus going cheap will always be more expensive later. Definitely educate yourself on what you want vs. what you need.
It's a 4 door. And I'm trying to do things somewhat on a budget right now but do get what you mean by not going backwards. And I like to stay as close to the factory ride as I can
Use a spacer lift, or budget boost, as it's also called. That's the cheapest route.
Or an EVO leveling kit, or Rancho 2" Sport System
Drive it the way it is winter is around the corner save a little bit more through the winter and research a bit more.
