Lift for 2025 Wrangler Rubicon
epriev
Man, you Jeepers have so many options for lift kits compared to Nissan.
I think I have found a lift to start out with. I plan to run the 33s for a bit, then switch to 35 or 37 after I get a feel for the Jeep and this lift.
Jeep Wrangler 2.5 INCH (GAS) JL JLU LIFT KIT ENFORCER SUSPENSION
Stage 4 overland with front & rear track bars.
Should I need to add the steering correction or any other parts?
Cobsidering adjustable shocks, but the bilsteins have seemed fine in the xterra.
The install looks doable thanks the WAYALIFE videos.
Thanks again in advance.
That’ll be a great lift. My first lift was a 2.5” and I never changed the front track bar height; the kit came with only the rear relocation bracket. I didn’t have bump steer at all. However, it’s better to have the track bar and drag link parallel so it wouldn’t hurt, and you’re already down there so…
Upvote 0
the kit has drop brackets so it should remain parallel, installed the AEV similar kit and never had any issues with bump steer and the stock track bar
Upvote 0
Though I have a JT I do have EVO's 2.5-inch lift. You won't regret getting this lift. All around performs great with the Bilstein's on and off road. Definitely recommend going through Jeremy at Disciple great discounts and awesome shop!
Upvote 0
