BillTheCat
Looking for suggestions on flush mount LED tail lights with backup lights integrated into a single unit.
Thanks!
Thanks!
I'm not sure if you're looking for something like this, but I see these a lot in my area.
http://www.northridge4x4.com/lighti...o-usa-jk-2007-15-black-led-tail-lights-311212
Okay gotcha well I found this page on extreme terrain
http://www.extremeterrain.com/offroadonly-lite-panels-jk-ld-lb.html
Oro lite dots can be flush mounted, and I think the genright skins can take them. Evo also uses flush mount, but basically anything will require a skin to mount them. I did run a led tail kit (http://www.rockridge4wd.com/ROCKRIDGE-4WD-LED-Tail-Light-Conversion-KIT-p/pan-5002.htm) but the lights angle out which is kind of annyoing and also if you plan to do corners after, there is not much metal left from the cuts those require.
Maxxima led tails mount on top of the skins, and have a back up integrated which a lot of guys on here are running and happy with. Once again tho, other than shaving the stock tail light holes, you will need corner skins from someone.
http://ecx.images-amazon.com/images/I/91p85VolHcL._SY355_.jpg
That's what I'm looking for!!! Goin' need new skins though.
I've been running the new maximmas slim line version for about a year and half since they first came out. No issues. I like the look.
New skins required?
Closest to flush I've seen without having to install corner armor skins is the MetalCloak:
http://www.metalcloak.com/JK-Replacement-LED-Tail-Light-p/3432.htm
How do the maximas mount? Half tempted to try them before I cut for the std lights with the gaskets
