LED pods
ob_tj
I need a little help. Not to sure where I should mount these. I like both of them. Up on the bar, or out on the sides which would cause me to have to drill some holes. so I need some input. What do you guys think?
Hmm, I guess it depends on the spread of the light output and what you are trying to get. Generally though, I would probably mount them under the hoop if possible. If you can't go under then I think over would be my next choice.
I'd go with the lower position. If the pods and your headlights are at the same level, you aren't getting as much added benefit as if they are coming from two different angles to illuminate what's in front of you.
Also, keep in mind protection should your rear end someone. Moving them back 2" won't affect your lighting but may save you from having to buy new ones.
