ramjeepgreer
Wife bought Jk leds headlights for Xmas. Will they work on my to?.
Yes, the size is correct, and granitecrystal is also correct, you need the h4 to h13 adapter prevously mentioned, as the h4 is the same connection as stock TJ lights.
Oh hey, just reread. You are putting jk into tj, not the other way around. I am not sure they make h13 light to h4 harness. Probably do, but make sure that is what you look for.
I do know some led headlights came h4 even for the jk, so maybe you will get lucky and it will be the h4 style. Check for three prongs on the back, and google to see what h4 and h13 look like.
This is an h4 bulb, the same contact pattern as a stock TJ, which will connect to a TJ harness/receptacle.
This is an h13 bulb, which will connect to a JK harness
So if you have JK headlights with a JK contact pattern, you need this harness
Hope this helps you find what you need
