Eagle1911
Looking for some guidance as I have run out of ideas.
This is for a 2021 Mojave. I replaced the plastic bumper with a Mopar steel bumper that has LED Fog Lights already installed. The bumper took some damage in shipping, but nothing I wanted was damaged. I got the bumper mounted as well as a Warn winch with a Warn winch support. I then replaced the headlights with LED bulbs. I used the Taser JL Mini to change everything over to LED from halogen. Headlights work great, but the Fog lights will not turn on. I tried just several modifications with the Taser and had no luck. I have verified there is voltage at the connector to the LED. Even removed the halogen fogs to check if they would work and they do. Even swapped the wire harness with no luck. I am out of ideas. Is there something I missed or any ideas?
