silverbackjk
Every so often my dash light looks like lightning bolt and traction control light come on at the same time and I loose all throttle control? Any ideas what is going on with this?
Like this? Happened to me the other day.
<img src="http://wayalife.com/attachment.php?attachmentid=16158"/>
Are you running a Sprint Booster?
I turned mine off and turned it on and that light and reaction control went off. Check engine stayed on though. I reset the battery and check engine turned off.
is your steering wheel centered.
Check engine is typically an emissions related issue and more times than not, related to your EVAP canister. The lighting bolt is an ETC issue and sometimes, leakage from a CB coax cable too close to the accelerator can trigger it. Sometimes, it's just a bad wiring harness or issue with the throttle. I might have a dealership use a scan tool to figure that one out. The traction control light is typically a steering wheel not centered issue but, if it persists even after resetting the computer, you might have a bad speed sensor.
I cleaned my Throttle Body today and did this with out disconnecting .....and now I sound like I'm idling a harley
I'm going to leave it alone but there are just so many jokes that could be posted back.:cheesy:
What codes is it throwing. The rough idle almost sounds like a vacuum leak.
