hey all,
does anyone have an idea or a solution on how to wire the amber backlighting of KC flex era 4 to the DRL/Side marker light of the JLU Sahara. I am just not able to wrap my head around it. when it comes to wiring I find it too chaotic. if anyone on here can advice which wire/fuse to tap will be of great help.
on another note. as the DRL has two stage lighting day light running mode (bright) & a dim mode (dims when headlights turn on) this is stock from the factory. my question is will this dim function turn off the amber backlighting on the FE4 or just dim the backlighting as it is on the same circuit as the DRL/side marker. i am looking for a solution where the amber backlighting will turn off when I turn on the floods.
thank you,
Nix
thank you,
Nix
