Sporadic
So, I had an AEV 2.5 inch suspension lift installed (no correction brackets), 35x12.5 R18 tires added and JKS Quicker disconnects on my 13' JKU.
After a little drive time, both highway and in town, I've noticed some "wondering" in the steering. Meaning, my rig wants to follow the contours of the road. I took it back to the shop for a test drive and they tell me next time I get an alignment have the toe out adjusted a few degrees and that should correct the problem. Is this correct?
I've found a few posts (and write-up ) on this forum to look at the caster and corrections can be made by adding upper and lower control arms. Would correction brackets help?
Any suggestions on which way I should go to try and correct this issue would be much appreciated.
Thanks,
Ty
Thanks,
Ty
