When I had mine off during the swap and adjustments, I didn’t have any play like that. I have 35k on them and they were tight as a bell.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Watched the video, that looks like a ton of play, are the threads on the JJ itself ok?
The crush sleeve portions are not lined up
2015 JKUR AEV JK350
1985 CJ8 Scrambler
YesSince that is the adjustment would it not always line up like you would a tie rod? If that makes sense
Do you know if the notches I mentioned on yours were clocked together?
That’s a ton of play... I’d probably replace the rod end and adjustment collar. I had a small about of play on one of mine and the pinch bolt was tight to the point that the pieces that the pinch bolt goes through were touching each other. Mel told me to take a cutoff wheel and make the slit bigger. Haven’t had issues since.
Good that you've ordered new inserts, that insert may be wallowed out causing it to have that much play?
The inserts on mine have zero play at the insert and over 150k miles on them.
I should probably take them apart and check the bushings while i have idle time :hmm:
how far into the control arm is the stud of the JJ (trying to ask that without setting this up for shaft jokes lol) looks like it may be threaded out too far?
