Man that sucks, looking to maybe trade ....having very hard time finding a Rubicon extreme recon v6Sadly a recall issued with no fix is very common. There was a GM recall that was open for about 3 years that parts just became available last year.
Why do you want to trade? Just cause of the fuel pump deal?Man that sucks, looking to maybe trade ....having very hard time finding a Rubicon extreme recon v6
Well I’ve read the diesels are notorious for all kinds of problems.I don’t plan on trading. No reason to. The problem is there, but not as wide spread as many think. I wouldn’t worry too much about it until you have a problem, that most likely won’t happen. The chances of that piston turning are pretty small, although it does happen unfortunately. Enjoy your Jeep and don’t worry about what may.
There is a recall on the cp4 pump with no replacement or fix....cam roller doesn't have a roll pin and turns in wrong direction which causes metal to metal wear into fuel injection
Wasn't there a similar issue a few years ago with Bosch pumps in GM diesels fucking up the whole engine?Sadly a recall issued with no fix is very common. There was a GM recall that was open for about 3 years that parts just became available last year.
Yes. It’s the same CP4. There is a company doing retrofits for them back to the CP3. Now Ram and stelantis are doing there own factory retrofit. The 3.0 is much easier due to the pump being right on the front.Wasn't there a similar issue a few years ago with Bosch pumps in GM diesels fucking up the whole engine?
The interwebz are always right. Even those that have never seen one know all about them.Well I’ve read the diesels are notorious for all kinds of problems.
