Thanks Eddie. A few months back, I purchased 37s/ATX Slabs and I’m now looking to re-gear to 5.13. Estimate $1,200 in parts/labor to re-gear the front/rear. I thought rather than pay labor to re-gear a factory dana 44 with 5.13 gears, why not put those “re-gear” labor dollars towards the installation of stronger axles knowing I'm going to keep this jeep for the long term future. Sure, it’s going to a cost a lot more, but just receiving a 2 year interest free credit card and knowing there are 2 years of tax returns in between helps convince the wife this is a good move. :thumb:
The first call I made was to Dynatrac. I’ve made so many calls now I may be off on my numbers, but I think for the rear they quoted $4,850 or so for a fully built 60 with ARB, 5.13 gears (I believe with 35 spline axles). At the same time, I can get a fully built Currie rear rock jock w/ ARB, 5.13 gears, 35 spline shafts for $3,615 (~$200 more if 40 spline axles and 40 spline ARB). I’m sure there are good reasons in terms of strength/quality for the price difference, but it’s not like I’m going to be entering KOH or running carnage canyone anytime soon. I’m only interested in running trails like Fordyce, Rubicon, Dusy, etc with added peace of mind of the 60 axle strength. Both the Currie and Dynatrac would allow me to run my 5x5 ATX slabs too (maybe not a great thing, but I’m so not interested in selling my ATX slab wheels and dealing with swapping them out for a different bolt pattern wheel).
For the front, I first looked at the Pro Rock 44, but because I’m running RCV shafts I thought the 44 gears would still be susceptible to breakage given the strength of my RCV shafts (I’ve never had a problem to date btw, but everyone seems to think I’m going to blow my 44 gears). I also realize the PR 44 housing is a ton stronger compared to the factory axle assembly, but at the same time I wanted to investigate a 60 housing/gear option w/o having to pay the costs for a fully built 60 nor deal with swapping out my ATX Slabs. And that is when I stumbled across this Currie axle assembly. Seems like a good solution for my needs – 60 housing, 60 gears, 60 tubes (will verify thickness), can continue running my RCV shafts (or sell them and run the shafts included in the kit), new tie rod (can sell my RK 7075 alum tie rod) and also continue running my ATX Slabs. Perhaps throw in a set of Reid Knuckles which should make for a pretty strong setup. If I were to purchase the PR 44, I would still be running my ATX Slabs, RCV’s and the same spline shafts anyway, but w/o the 60 gear strength.
In the end, provided the quotes I’ve received from my installer, for Currie parts only (front/rear axles, ARB, compressor, gears, shafts, etc) and assuming I sell my factory Dana 44 axles for what I estimate they are worth - net cost for parts listed above is $5,200. Not bad for a fully built 60 in the rear and a hybrid 60 up front. Of course this does not include labor to install the axles or plumb the ARB.
If the front axles were free, which setup would you prefer and why?
1) Pro Rock 44 housing (then transfer all factory parts w/ RCV shafts, new 5.13 44 gears, ARB locker, maybe throw in Reid Knuckles)
2) Currie 60 assembly (transfer factory outers, 60 housing, new 5.13 60 gears, RCV shafts, ARB, maybe throw in Reid Knuckles)
Thanks!
