Hope somebody had this issue. I am installing the PSC big bore setup, with cooler, in my 2012 JK. All hardware is installed, not a problem. Pressure line installed. It's the low pressure side (return) thats got me hosed (literally). The reservoir has a 3/8 inch barbed fitting. The return from the steering box to the cooler and all cooler fittings are for 1/2 inch hose. Theres the issue! I have 1/2 fittings on the outlet of the cooler and 3/8 inch fittings on the inlet to the reservoir. WTF? EVERYTHING in the kit from PSC is 1/2 inch barbed fittings except on the inlet to the reservoir. Would it be an issue if I put a 1/2 inch to 3/8 inch barb reducing the size downstream to the reservoir?
Any insights would be helpful.
BTKillerr
BTKillerr
