rogerk93
The past week my Jeep will start to overheat after 10 min into driving and randomly get back down to normal temp for a second then temperatures go right back up. I check the coolant reservoir and it is filled to the top which I did not add that much. When I checked the level in the radiator it was a little low so I would add some coolant and start to drive again. After driving around for a couple minutes I notice coolant all over my diff and the coolant reservoir has more coolant in it then before and the radiator is a little low again and the overheating starts again. I don’t think it is the water pump as I don’t see any leaks or hear any noise. But I’m uncertain on how to check to find the problem.
