x2 ^^^^ but maybe specify different height for JK vs. JKU??
Max height on a 4 door; measured at the top of windshield / a pillar, to the ground = 83"
My 4 door on 40"s measures at 81" to top of "A" pillar or about a 3" lift equivalent
I run a 3.25" lift and I think it's perfect.
I did add a 1" spacer in the rear to compensate for the weight of the spare, rear bumper, and gear in cargo area. Sits level!
X2 on that Keoni,I did the same with my coil lift and I'm sitting about the same height :thumb:
Although you are on taller shoes .
You going to do 37's Ed?
and have you found that this height works well at both the Scottsdale Fashion Square as well as the Metrocenter Mall?![]()
Why yes, as any vehicle 83" tall (or less) will fit into most covered parking spaces and garages, which helps not only protect the jeeps paint from sun fading during extended shopping sprees....but also keeps my metrosexual self in the shade, which lessens the damaging effects of the sun on my delicate skin.
How did you come up with 3" of lift? Seems like more. I'm at about 73.5"-74" on 37's. that puts you 7" taller. Granted the 40" tires add about 1.5"-2" of height over my 37". By those calcualtions im lower than stock lmao. I snapped a pic of another rig on 40's with DTD and its hella taller than mine. The rig in the pic also has the same fenders and makes the comparison easier. Here's that pic and my measurement I just did View attachment 58656View attachment 58657
That's Dave's rig, our set ups are identical with the exception that his coilovers are dialed in higher than mine. I am comparing what I have now to my old set up
Old suspension= Teraflex 3" with 35" KM2's- top of windshield measured 79" to ground
New suspension= coilovers with 40" Mud Grapplers- top of windshield 81" to ground
I got it. So it's not an actual 3" of lift but sorta what a 3" kit would yield. I'm at 2.5" over stock. So if you are 7" taller minus the 40" tire difference you are running a little more than 7" of actual lift? I'm curious because I've parked next to moby and I know Eddie always says he's only running 3.5" of lift and its way taller than mine.....not an inch of suspension plus bigger tires
Edit: looked at an old post and Eddie says its at 4.5" over stock
