JKFlyer
Hi...I have a specific question that I couldnt find in a search. So when you remove the hardtop and disconnect the harness, I think it deactivates it all...rear wiper... fluid...etc. ....I suspect BC I was so curious that when I put my soft top on, I had to test the rear washer fluid and it didn't push any liquid out (but did work when hooked up). So this is my assumption...
That said, I got an aftermarket hard top from Wild Boar. I need to hook up the defroster wire to the thicker cyan colored wire in the harness. I did this and sodored it up, but it doesn't seem to be doing anything. Also, the rear defroster button does go on and stay on when pushed, but it did before when I had the soft top on and it wasn't connected.
I know its wired and sodored right...so my assumption remains that unless the harness is plugged in, it remains inactive and thus My rear defroster is not working. If I am correct, I would just need to jump or connect one of the wires in the harness to another so it thinks it is connected and the defroster will work.
Does anyone have any insight?
Thx
Mike
Thx
Mike
