THIS!! Yup. Have had about all of these on my 08 JK. Following are a few things ive done in a effort to fix.
Issue:
Wiper issue where they turn on mysteriously/ hi speed wiper does not work also had the odd display light show.
I replaced the relays on the TIPM. Thought this fixed it. But the issue came back a after some time. Was a PIA only recommend if you are comfortable with circuit boards and soldering and have lots of patients.
Open the wiper motor assembly, clean up the extra grease on the wiper assembly contacts( only takes about 20 minutes, this too fixed the wiper issue. But again it came back at a later time)
Clean the contacts within the steering column. Specifically the blinker and wiper control unit connections (this also provided a temp fix). Only took about 20-30 minutes.
Added a additional ground strap from the battery neg terminal to chassis point). Didnt fix the issue but i left it there.
Opened and cleaned as many connection points i could find. Didnt fix the wiper issue
Seems the issue has to do with a very sensitive/ low tolerance voltage or resistance setting ( just my guess). I haven’t found the Golden egg yet. Im still searching. My wipers are currently effected. So i pulled the relay from the fuse box. Prob solved
. Not a issue as it doesn’t rain much in So Ca.
Good luck in your search. Post up anything you find that provides a fix. -M
