Otzy
Hey yall,
a few questions, if i was to go with a very complete lift kit such as a full traction 3" ultimate lift kit. what else would be needed to get my rig up on some 35s and wheeling. From the little bit of research that ive done i would also need a double cardin u joint drive shaft. Can anyone explain to me what that actually is and why its needed. and then seeing as i dont have a rubi i plan on detting a dana 44, is that necessary immediately or is that just a nice addition?
the full traction lift kit comes with 3″ taller coils, adjustable lower and upper control arms, adjustable front and rear track bars, bump stop extensions, brake line relocation brackets, new longer sway bar links for the rear and sway bar link disconnects up front for X and Sahara model JK’s.
will all that really be necessary? If so i have no problem paying for it, but for a newbie like me comparing that to an old man emu kit which comes with 3″ OME HD Front Coils3″ OME HD Rear Coils, Front OME LT Shocks, Rear OME LT Shocks, Currie Adjustable Front Upper Control Arms, JKS Adjustable Front Track Bar, JKS Adjustable Rear Track Bar, JKS Front Disconnects, NR4X4 Adjustable Rear Sway Bar Links, Crown Extended Front Stainless Steel Brake Lines, Crown Extended Rear Stainless Steel Brake Lines, TeraFlex Front Bump stop Extensions, TeraFlex Rear Bump stop Extensions, Currie Rear Coil Retainers.
So whats the difference between the two? from what i can tell they consist of more or less the same components, but what makes the full traction kit so much more complete and expensive than the EMU?
is there anything else which is necessary to start wheeling without damaging or rubbing anywhere?
Thanks for any help which you can provide guys, its all a bit confusing at the start!
-Otzy
-Otzy
