Hey guys, so I just recently went off road with my jeep today. I got stuck in a decent water hole. Enough to to cover the bottom of the doors. Naturally water came in. What's the best way to clean the carpet. I know I have to take them out.
Bedrug Bedtread and left all the drain plugs out. Now there is no carpet to get dirty or soaked and the water just drains out on its own.
How do you like the Bedrug?
I even modified it to retain the use of the Mopar slush mats.
Taking the whole carpet out is very easy and that is what you should do. Just take out the seats and couple of push pins then you're done.
Oh, drain plugs are located one each under the driver and passenger seats, one each under the carpet where you feet go in the footwell, one each under the carpet in the rear footwells, and I believe one each under the rear seat, but not sure about that last one. I took the carpet out of my new Jeep and run the Bedrug Bedtread and left all the drain plugs out. Now there is no carpet to get dirty or soaked and the water just drains out on its own.
Just remember if you unbolt your seats that you put them back in at the right torq specs. But it's pretty simple after you've done it a time or two.
As for the drain plugs, should be one in each foot well and one under each seat. There is also one in the cargo where your factory jack/tools are located.
To be fair to the OP though, there is no reason to unbolt the seats to remove the carpet. There are pre cut sections that just have a small amount of material keeping them together. One good tug and they come apart into their intended sections. I removed my factory carpet multiple times and installed the BedTread without removing the seats. OP, unless you have a reason to, I would personally not remove the seats just to pull the carpet.
I'm planning to get a Bedtred since it is more of a bedliner type, though I'm curious if it works with the factory drain holes?
How so? I just got my slush mats and really don't want to get rid of them. LOL. Though with the bedrug they may be just for looks.
Hi!
This weekend I went off road with my friends. My jeep is filled with mud, dirt and dust. So someone please suggest me a cleaning service for my jeep as soon as possible.
Your suggestions are welcome.
Thanks in advance.
Hi!
Thanks in advance.
Welcome to WAYALIFE .... give us a wave and I agree with WJCO... garden hose and some elbow grease.Hi!
Thanks in advance.
