It's quite possible you need to have your ECM reflashed
Sent from my whatchamacallit
That's what I'm worried about. Is it something the dealer has to do?
Sent from Chewbacca
Curious how it got interupted? Just hoping to avoid the same thing.
Sent from my LG-D800 using WAYALIFE mobile app
I'm at work an got an emergency call while programming.. Stupid me, I brain farted and turned off the ignition while it was programming
Sent from Chewbacca
Dealer charged me $250 for a flash, but beware, they tend to frown on the use of tuners for some reason.
Sent from my DROID4 using WAYALIFE mobile app
My tuner just started acting up after I updated it. If I go into the Advanced Tune settings it says "cannot detect ignition on" but when I go into the Quick Tune setting it seems to work fine. I haven't ever updated it in the two years I've had it and last week I thought I would update it because I thought I could set the gas pedal sensitivity/ throttle delay. After updating it didn't give me any new options and now it's not working properly. Just my luck!
After reflashing, i assumed the jeep would then start? I am considering replacing the ECM and is wondering if that would take care of my not starting.Dealer charged me $250 for a flash, but beware, they tend to frown on the use of tuners for some reason.
Pssst. Date check. Noob bumped.Have you tried to pull the neg battery terminal for a few minutes and see what happens? Do you know at what point you turned off the jeep, was it while it was backing up your stock config or while flashing a new settting or tune? Can you get to reset to factory option if it has one?
