Jeep TJ Error Codes
Jranso04
My Check Engine light has been on for about a year now in my 2005 TJ and now my Check Gauges light is coming on. I checked my sensor codes on the odometer and the codes are P2096, P0137, P0158 and sometimes P0157. What do these codes mean? I am pretty sure it deals with the o2 sensors but I’m not sure. I think the Check Gauges light is on because my Oil Pressure sensing unit needs changed out but I’m unsure. If anybody could help that would be great!IMG_0687.jpg
Start with a basic search on the Google or get yourself a Service Manual. You're going to need it anyway and they're like $35. Might not Bevan easy fix. All of this was found in less than 1 minute.
Basically. Start with finding all of your O2 sensors and making sure one or more aren't plugged in or have melted wires. If everything looks okay, go down to Napa and buy ALL new O2 sensors. You've let this go on so long you've probably got a burned out cat converter.
You also been stopping at the fuel pump more often than you should as you're running rich. They don't put these lights in to make your dash board pretty. They mean something. Read your owners manual!
P2096: https://www.yourmechanic.com/articl...el-trim-system-too-lean-bank-1-by-elan-mcafee
P0137:
https://www.yourmechanic.com/articl...it-low-voltage-bank-1-sensor-2-by-jay-safford
P0158:
https://www.yourmechanic.com/articl...high-voltage-bank-2-sensor-2-by-jamahl-walker
P0157:
https://www.yourmechanic.com/articl...-low-voltage-bank-2-sensor-2-by-jamahl-walker
Thanks for the advice and information. I’ve been wanting to get things fixed on it for a while but I don’t have the money. I’m currently in college and working a crappy 7 days a week job but I will save up for sure.
